e30 issues!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by micflair, Oct 6, 2004.
  1. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Help meeeeeee! My e30 has recently started to play up, it takes some dvds (originals) and not some.. takes some dvdr... and not some.. the error it comes up with on the screen is U11 READ ? Anyone know what this is all about, ive tried cleaning it with a lens cleaner, then realised there is a special dvd lens cleaner.. duh! Anyone had this problem?
    Mick
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The U11 error means invalid disk - and the prime cause of this is a dirty lens. Pickup a compatible lens cleaner to solve your problems.
  3. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Argh, I tried using the dvd lens cleaner from my local argos.. still nothing guys!! anymore suggestions?
