E2180 M0 stepping - the super O/C
meizumintyboi
Just building a new rig atm:
Gigabyte S755 GA P35C-DS3R DDR2/DDR3 1066/1333/800, SATA II, SATA RAID, ATX
E2180 (2GHz) 1MB L2 Cache (2x512k) M0 800MHz FSB, using stock fan
OCZ 2GB Kit (2x1GB) PC26400 Gold Edition XTC 5-5-5-12
Triplex PCI-E X1950 Pro 512MB GDDR3
Kingwin ABT-520MA1 520W Modular PSU
PATA-SATA converter
total about £300 inc. VAT & Shipping
along with some old rig parts:
1xPATA DVDRW
2xPATA HDD
1xSATA HDD
ATX gaming window case
3x80mm LED case fans
1x120mm LED Akassa case fan
PCI Creative Audigy 4
PCI 4 port firewire card
I currently await for the arrival of mobo & PATA converter. So i am standing at my front door outside waiting, whilst posting this thread on my laptop, battery low... not
now with this set-up i was wondering what i could get my E2180 to O/C up to, using stock air?
the thread below has various links to various O/C info on the new Dual Core E21xx M0 series CPU's which apparently O/C far better than L2
"If we consider that the best copies of processors Pentium e2xxx stepping L2 are overclocked using air to 3.6 GHz, then from M0 stepping representatives it is possible to expect more impressive overclock. "
http://forums.hardwarezone.com/showthread.php?t=1701638&page=4&pp=15
and here's another link about the M0 & what the chip looks like (yes, i checked, my E2180 has M0 according to the photograph)
http://xtreview.com/addcomment-id-2814-view-Pentium-E2xxx-M0-stepping.html
booyaka
there is no set amount you can overclock by - it's all dependant on loads of factors including the ram, the cpu and the motherboard etc etc.
Best way is just to take your time and nudge the FSB up and keep stress testing it all the time.
meizumintyboi
so with the spec i have do you think i can get an O/C up to 4GHz the motherboard is a solid overclocker, & the ram is is for enthusiast overclocking. (EVP-Extended voltage protection)
using stock intel cooler, which is actually a pretty decent cooling unit
____________
Hiro Nakamura! I must go back in time & stop the bomb!! lol ***
pjclark1
You will be unlikely to get beyond 3GHz
meizumintyboi
3.7 GHz - > 1.67 v. Using only air cooling
meizumintyboi
ahh 1.67V that's ridiculously high even on phase, would reduce lifespan of cpu drastically
booyaka
1.67volts is ridiculous amount to pump through your cpu.
On stock air cooling - it's all about temps. That is the driving force behind how far you can go with your overclock.
At a push you could put 1.5v through the cpu for benchmarking etc but the max i would push on a regular basis through mine would be 1.45volts assuming the temps are ok.
Use coretemp or TAT to monitor your temps when under full load. Max under full load for 12hours or so should be about 65 degrees.
If you get towards 3.2ghz or so, with good temps, that is an excellent overclock.
make sure you use Orthos or alike to stress test, a proper stable overclock should be able to survive 12hours or Orthos on both cores @ 100%.
GLP1
Nice Result
Very interested to know what this processor can achieve at stock voltage.
Been Closely following the 2140/2160 thread on extremesystems.org forum
http://www.xtremesystems.org/forums/showthread.php?t=145328
Care to post some results with 1.325Vcore
How high did you have to go with the NB and SB voltages?
And how hot did the CPU get?
Got a Asus Commando mobo at home waiting for something to do.
Gavin
meizumintyboi
http://www.overclock.net/hardware-ne...-0-ghz-m0.html
i was just quoting what that guy had done in the forum above
i still havn't even got my GA P35C DS3R (£74 inc. VAT & shipping from E-Tropolis, apparently best O/C chipset & mobo in general) yet lol, due this friday. i will post here to let you know what i get out of O/C, do you think my RAM is decent enough?
OCZ 2GB DDR2 CL5 PC2-6400 Gold GX XTC Dual Channel EVP up to 2.1V (+-)5%
GLP1
I suppose only time will tell.....
A lot of the guys are using PC8500 or better.
I would be a bit more concerned with the stock CPU cooler and getting a couple of fans over the North and Southbridge Heat Sinks.
Keep us posted to how you get on
Gavin
meizumintyboi
yeah i couldn't afford the faster ram, i didn't really want to dish out lots of £££ on faster ddr2 memory, i will save up for a future upgrade of low latency DDR3 memory when prices will gradually decrease
i am considering a zalman, but then again i do plan to upgrade cpu in the near future
what size fans do i need on north/south bridge?
GLP1
What sort of case have you got?
I personally would n't use a Zalman if it was free.....
If you have the space go for a Tuniq Tower 120, Thermalright 120, Scythe Infinity, or a Noctua NH-U12F etc. These can all be used if you upgrade to a high spec Core 2 Duo or Core 2 Quad later
If space is an issue consider the Thermalright SI 128
Regarding Fans, this really depends on whether this is an overclocking exercise, or you are actually building a pc to use that can overclock when you require.
If its the former, high airflow fans are best, these will be noisy.
Otherwise fit a quiet 12cm fan(s) to draw air over the the chipset heatsinks.
Gavin
meizumintyboi
ok thanks for the reccomendations
it's no case in particular just some random ebuyer case with a window, quite roomy though
1 80mm intake fan on window, 2 80mm extract fan on rear, 1 120mm intake fan on front pannel passing through HDD bays.
yeah i havn't really put any bets on this system, it will be getting some ddr3 action & a better cpu
pjclark1
I still predict you won't get more than 3GHz out of it.
It will be interesting to see which of us is correct.
Reviewers (usually) get hand picked CPUs, you will get one off the shelf.
GLP1
The L2 2140 and 2160 retail CPU are capable of 100% overclocks
so 2180 should easily manage 301FSB x10.
but I agree with you it will be interesting to see some hard results.
Gavin
booyaka
i'll back him to get 3ghz out of it!!:D:D
I'll make sure he does!:rotfl::rotfl:
meizumintyboi
you'll make me eh? lol
meizumintyboi
rulocal
Any news on the o/c?
meizumintyboi
yes o/c to 3.02 GHz stable using stock fan had PC on for about 4 weeks temp 50-60 celcius tops
rulocal
Great. I have the same CPU/Mobo and Ram arriving tomorrow with an 8800gt card. Hopefully I will hit 3Ghz too.
Cheers.
meizumintyboi
yeah i ran it at stock for about 2 weeks at 1st, o/c, with my whole spec, playing the latest games were a breeze maxed out at 1680x1050, i can't tell the difference after o/c? when running many appz simultaneously still seemed good no dif to me
meizumintyboi
yeah i ran it at stock for about 2 weeks at 1st, o/c, with my whole spec, playing the latest games were a breeze maxed out at 1680x1050, i can't tell the difference after o/c? when running many appz simultaneously still seemed good no dif to me. obv wen ur playing dx10 games, it will be a lot slower even with ur gpu and depending abt ur other specs
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
Latest News
Samsung's 110-inch Micro LED TV on pre-order at Harrods
  • By Andy Bassett
  • Published
Bang & Olufsen introduces Beosound Emerge speaker
  • By Andy Bassett
  • Published
Sony launches native 4K VPL-VW290ES and VW890ES projectors
  • By Andy Bassett
  • Published
AVForums Podcast: 14th April 2021
  • By Phil Hinton
  • Published
Ruark introduces R5 Signature audio player
  • By Andy Bassett
  • Published
