E-Pilot SRC-9200 - Help!
Discussion in 'Home Cinema Control & Remote Controls' started by andrewuk, Aug 1, 2005.
  1. andrewuk
    andrewuk
    I have an E-pilot SRC-9200 which now has stopped working. The screen is just blank, I have tried new batteries and nothing. Can anyone provide me with the following :-
    1. A link to the manufacturers website
    2. Any ideas on what might be wrong
    3. Contact details of repairers
    4. Websites where I can buy similar (e.g. SRC-9200, SRC-3000)
    I guess the repair option might not be viable, so any info on where they can be bought from at a reasonable price would be excellent.
    Many Thanks
    Andrew
  2. andrewuk
    andrewuk
    Anyone?
  3. johndickinson
    johndickinson
    Jan 9, 2003
    375
    28
    +28
    I have the same remote and the buttons on the far right are starting to fail.
    Go can get a cambridge audio one from www richersounds.com or their highstreet shops for £49.95 or Maplin have the SRC 3000 for £69.99 www maplin.co.uk product code L81AR
    Check for affiliate links
  4. andrewuk
    andrewuk
    Thanks for the reply. I appreciate that. Any additional links to retailers would be gratefully received.
