E-Pilot remote controlers
Discussion in 'Home Cinema Control & Remote Controls' started by scaniaman, Apr 1, 2001.
  1. scaniaman
    scaniaman
    Can anyone out there give me some info on this gizmo.
  2. Brigadeer
    Brigadeer
    Upgrade to the Angel this touchscreen lcd remote allows you to control up to 8 systems. You need original remotes as it "learns" from them. It also has custom key layout (covers majority of functions) and backlight. Got mine from Lektropacks in Hounslow. About £80-90 + postage.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I think I paid £70 for the Richer sounds version. It is my only sucessful Richer Sounds purchase. I have now upgraded to the Marantz version of the Pronto but I still like the old remote. It sits easily in the hand, easy to program and sturdy.
    I throw it around on couches etc, zero problems. Batteries last a long time too. All in all, highly recommended.
    The only down side is the fixed arrangements of keys but I managed to program it for everything even if some of the labels weren't excact.
