e-mail
Ally
Established Member
Joined
Feb 6, 2009
Messages
223
Reaction score
5
Points
77
Hi, i've just installed Thunderbird for my e-mail as i would like to use it instead of Outlook, i have everything set up apart from the part where i need to enter my password to be able to send/receive e-mail, but for the life of me i cannot remember it, anyone got any ideas as to how i solve this problem?
thanks
thanks
You can do it online. It will not give you the old PW, but you enter a new one and use that. THe process requires that you answer a security question that you defined when you originally set up the account. If you can't remember the correct answer to the security question then you'll have to call VM and ask them what your email account password is.
Connecting you - Virgin Media
Go through the motions until you see the option relating to forgotten passwords.
Thanks mate, but done all that, changed my password successfully, but when i try to "get mail" on Thunderbird the password box comes up and i enter my new "changed" password and it doesn't accept it?
I'm well and truely stumped......:lease:
Leane it a while. I've had similar problems before and the VM mail servers appear to take some time before they start accepting the new PW. If you still get no joy, I can only suggest you contact VM about it.
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
