E-mail and Archos 7
Discussion in 'Video Streaming Boxes & Services' started by katxx, Feb 9, 2009.
  1. katxx
    katxx
    May 6, 2006
    4
    My lovely hubby brought me an archos 7 the other day for my birthday but im having trouble setting some things up and wondered if any of you know the answer.
    Ive got a virgin.net e-mail addy (currently using incredimail)and wondered if there was anyway of getting this addy sent to the archos??
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If Virgin offer a POP3 route to collect mail then it should be possible, have you tried setting it up yet?
  3. katxx
    katxx
    May 6, 2006
    4
    Hi Mark,thanks for the reply.
    Yep been tring to set it up for the last 2 days but no joy.I have been putting pop3 in and smtp but theres something im doing wrong in the setting as it just doesn't want to know.The problem is im not very technical minded and either need to be told things in easy format or shown lol.
  4. derek1971
    derek1971
    Mar 13, 2005
    2,228
    Glasgow
    +300
    I suspect some of the other settings need tweaked. Under protocol choose "pop3"
    Under Encryption choose "none"
    Under Authentication choose "clear"
    Make sure you have the correct details for hostname, port (prob 110), login and password. Virgin should be able to give you these details if you don't have them or if you use outlook or outlook express check the settings in there and copy them.
    For outgoing again use "none" and "clear" for encryption and authentication respectively. Virgin should also be able to confirm the hostname and port and the login and password details will be the same as for the incoming server.
    Hope that helps.
  5. katxx
    katxx
    May 6, 2006
    4
    Thank you all for the replys and patience,i have now got it working and am very happy lol:thumbsup:
  6. hotshu
    hotshu
    katxx, I'm a newb too. What did you do to fix it?
  7. katxx
    katxx
    May 6, 2006
    4
    Hi Hotshu
    The problem i found i was having was that aswell as putting in the pop3,i was also trying to put in the smtp.In the end after i put the first pop3 in i left the other with whatever it came up with and it started working.Not sure if that helps or not lol:rotfl:
  8. m0aur
    m0aur
    Mar 14, 2009
    There is a demonstration video on the Archos site regarding setting up email.
    ARCHOS
