magicvinny
Established Member
- Joined
- Jan 22, 2008
- Messages
- 536
- Reaction score
- 139
- Points
- 99
Core Sub
I came across this subwoofer and did some online searching but could not find much people who are actually using this subwoofer.
If I look at the specs this seems like a killer sub:
Specification sheet for Core part 1
Do you think this would we a good sub for HT applications?
Woofer: | 4 x 9in |
Inputs: | Analogue and AES3 digital inputs (no sample-rate conversion) |
Resolution: | Maximum 24-bit / 192 kHz, depending on input signal |
(32, 44.1, 48, 96 & 192 kHz sample rates supported, analogue runs at 192 kHz) | |
Max SPL: | 120 dB |
Frequency response (- 6 dB): | 13.5 Hz – 200 Hz |
Frequency response (+/- 3 dB): | 15 Hz – 165 Hz |
Box principle: | Sealed enclosure |
Amplifiers: | Pascal Class-D amplifiers: LF 2 x 500 W |
Dimensions: | 390 mm, 365 mm, 514 mm (W x D x H) |
15 3⁄8in, 14 3⁄8in, 20 1⁄4in (W x D x H) | |
Weight: | 48 kg (105.8 lb) |
