Dynaudio Audience 82 system matching
Discussion in 'Home Cinema Speakers' started by nevC, Mar 1, 2003.
  1. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    Been considering the 82's as front speakers. Anyone have idea what centre and sub would match these speakers? Would the REL Q150 be dynamic and fast enough to keep up? Has anyone experienced a delayed effect with subs? I would like to build a system as capable with music as with home cinema. Would the JM Labs cc800 or B&W LCR6 S2 be suitable as centres?
    Any help would be appreciated.
  2. steve1056
    steve1056
    Apr 20, 2002
    384
    Reading
    +5
    I would recommend the Dynaudio Audience 122C as a perfect match for the centre. I use this alongside Dynaudio Contour 1.8's and IMO it's an excellent centre speaker.
    As for a sub, I would recommend that you wait until you get the 82's before getting one. The 82's go low to around 25 Hz (3db point), which is as low as many subs (excluding the really big designs). Unless you have a large room, I don't think you'll need a sub.
    BTW, I listened extensively to the 82's before I settled on the Contours. They really are superb speakers.
    Steve
