Dynamic range on yammy 1500
Discussion in 'AV Receivers & Amplifiers' started by dinoprada2003, Jan 30, 2005.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,734
    2
    LONDON
    +5,894
    Dynamic range on yammy 1500?
    Sorry if this has been addressed before but on my Sony/495 it was recomnded that dynamic range was set to MAX.On the yammy the manual doesent give a recomendation.Settings are.
    Dynamic Range.
    Min(if you listen at low volume)
    STD(general use)
    Max(to preserve the greatest amount of dynamic range)
    I want it set to the best setting for movie listening
    Thanks :thumbsup:
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,749
    Set it to MAX. This will give you maximum Dynamic Range. :)
  3. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,734
    2
    LONDON
    +5,894
    And hence the way the sound engineer wanted the DD track to be listend to yes? :)
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,749
    Yes. :)
    Quick note to any Denon owners who might be reading this. Leave your Dynamic Range settings to OFF if you want maximum Dynamic Range. MAX on the Denon's means Maximum Dynamic COMPRESSION.
  5. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,734
    2
    LONDON
    +5,894
    Thank you :thumbsup:
  6. CosmicOne
    CosmicOne
    dinoprada2003
    Jase was talking about the denon,
    while in the Yamaha it should be set to MAX (that means minimum or no sound compression)
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,749
    Said that in my first reply. ;)
  8. CosmicOne
    CosmicOne
    Jase
    i know dude but i repeat it for him to make sure Yamaha & denon have different setting,& not put his amp to minimum & that on Yammy means max compression.
  9. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    3,734
    2
    LONDON
    +5,894
    Thanks both of you and the yammys set to max as suggested! :D
    And in Arabic for Cosmic:
    Shookran habibi :smashin:
  10. CosmicOne
    CosmicOne
    3afoan ya basha,ae 7`adma.
