Dynamic range compression volume levels?
Discussion in 'AV Receivers & Amplifiers' started by Jeff, Jun 10, 2002.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Ideally we would all listen to DVDs at reference levels, but if this isn't an option at what volume levels should dynamic range compression be enabled? I normally go for -20 to -25db. At this level the loudest noises are fine but some things are just too quiet. It should be possible to chart the optimum settings, something like;
    0 to -15 DRC off
    -16 to -25 DRC low
    -26 to -35 DRC Med
    -35 to -60 DRC high
    Any ideas, opinions?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    DRC only works on dolby digital, not DTS and it's only on/off isn't it? or perhaps it's different on different recievers. I've got a marantz SR5200 and it's called night mode. I leave it off at all times and listen at about 60-65db (-18 to -25 on the reciever) most of the time, it's fine if there isn't any other sound in the room, i can hear pretty much everything. the reference level of 75db (-8 to 0 on the reciever) sounds great but only when the neighbours are out!
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    My Yamaha has 3 settings: MIN, STD, MAX - the latter non-compressed, i.e. DR off.
    Always use the MAX setting ...
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,750
    Mines set to OFF. I have the same options as Jeff does, same amp I think:)
    Never felt the need to use the DRC to be honest.
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    My question would be if you have DRC off and volume set to -20db (0@75db), aren't you potentially cutting off some of the low volume sound?
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,374
    United Kingdom
    +1,750
    I think you may be right, its possible you might not hear the very low volume noises. On the other hand with the DRC switched on you wont get that low volume to high volume jump when theres an explosion, which is what makes movies sound great!:)
  7. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    I have DRC always set at maximum dynamic range. The Lexicon has a DRC AUTO function, which adapts the amount of compression to the chosen volume level, but I don't use it.
    I have the following in mind:
    0 to -15 DRC off
    -16 to -20 DRC low
    -21 to -30 DRC Med
    below -31 DRC high
    But I think the best would be to have some sort of standard here.
