Dynamic DNS providers, which is best ?
Taz69
Hi all,
I am with Virgin and they won't allow me to use a Static IP, no BT line so no other option at this time.
As I have a CCTV system and the software to view them from around the globe uses the IP address not host names, from a quick search on the net I can only see people offering host names to ip address etc.
Which is the best to go with ?
Mark
JuzzyD
I've used both Dyndns and No-ip with no real issues, easy to setup and (depending on your router) you should be able to set the router to automatically update the address, if not then you can install an updater program on a pc inside the network.
