Dymo labels
Discussion in 'Computer Peripherals & Consumables' started by Pezerinno, Feb 11, 2009.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,462
    71
    Southsea
    +69
    Hi chaps,
    I'm finding the replacement rolls of DYMO labels rather expensive and wondered if there is a generic brand that does the same job out there? I'm sure there used to be some on amazon but I can't find them now. If they do exist where might I buy some from and how did you get on with them regarding ease of use/quality compared to the DYMO ones?
    Many thanks in advance!
  2. thisboy53
    thisboy53
    Dec 4, 2009
    3
    Tempe, Arizona
    I've found the best replacement deals on eBay. These items are dymo 'compatible' yet from my experience, they work fine (although a bit flimsy compared to the real ones). Here's the item. I purchased after researching similar items & sellers and this one passed my BS detector. I'm not sure if this will be helpful for you as a UK resident...but I thought I'd pass it along.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320454766893
  3. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,213
    Ebay!
