dying speaker grills a different colour
Discussion in 'Home Cinema Speakers' started by siy, Jul 19, 2005.
  1. siy
    siy
    Hi all - probably a bit strange, but has anybody ever tried to dye a speaker grill (made of material not metal) a different colour?
    I need to try to adapt a mission centre speaker to a white(ish) colour and wondered if it had been done before? i am sure it will need quite a few attempts as it's currently black, but have bought a spare one so that if the results are dreadful I can revert back to original black.
    Any tips/advice?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I would expect that recovering the grill would give a better result.
  3. siy
    siy
    good thinking - will give taht a go....
    next quetsion, where can I get some white speaker grill covering? :D
  4. skive
    skive
    Apr 30, 2004
    67
    Belfast
    There was a link for a company that sold speaker cloth on these forums a while ago - If you do a search it should appear - failing that google should bring something up! Looking to do something similar myself in the not to distant future!
  5. siy
    siy
    cool - will let you know if I find the thread
  6. Thomo589
    Thomo589
    You can get car head lining cloth basically the same as speaker cloth. Any car trimmers would supply (check yellow pages). Or car stereo suppliers they often use this material for accoustic parcel shelves in cars.
    Recently recovered my sub with head lining trim cost about £2.00 with great results :clap:
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  8. siy
    siy
    thanks - just called them but no answer, so left a message. good ideas too about the car headlining etc. As its for the centre I just want the best quality available.
  9. viper330
    viper330
    http://www.artcoustic.com
