Midnight Tboy
I've had my 607 Onkyo for quite some time now, paired with a Samsung UE55D8000 3dtv. its been flakey for a long time though, at first I lost the OSD menus, and then these days it takes about 15minutes to "warm up" to give me a picture, then works fine (other than the occasional click/pop from a capacitor
I've just finally caved and ordered a new TV, a Samsung 65 Q95T with one connect box, which should be delivered within the next week, but of course the old Onkyo doesn't support 4k, nor does it support Arc return afaik
I've seen the capacitor fix on youtube, even bought the capacitors, but have been reluctant to try and fix it yet, as it still works, and my soldering skills are ****
I then thought I'd test a regular audio device which had optical (found a DAB radio) and confirmed that just audio alone the sound works fine immediately on turn on. The OneConnect box was the ideal setup for my as the regular tv inputs are opposite end to where my devices are, as the tv is wall mounted, so I figured, ok I can have my devices inputted to the OneConnect box and then Optical from OneConnect Box to the AVR receiver in its sound input mode, as that would still support DTS (but obv not DTSHD (where the DTS stream would be used instead) nor TrueHD). I'm assuming the TV would let me bitstream the audio to optical
However, I now see that a lot of movies in HDR format seem to be TrueHD rather than DTSHD
Does that mean I won't be able to get any sound at all on these without doing some manual conversion? Or do mkv files with TrueHD generally carry an ac3 core with them? Trying to weigh up my options or possible workarounds
I have 5.1 setup, with a BK Monolith sub, and Focal Chorus 816/806v/cc700 v speakers, which I know outclass the Onkyo 607 itself, but it seems that to get something remotely similar modern equivalent to the 607 (well a little better) I'd have to spend around £600+ or so on something like the Denon AVR-X2700H, where I'd rather try and keep some life in the old unit until its on its very final breath, unless I'd hear a significant improvement in sound too as a result of course, but then talking lot more moneys
