tman
Does anyone know if DVR's (specifically Panasonic ES10) will up-convert an 'input' signal? I know if I have a device connected on the input scart, that it can record to DVD from that input, and also allow the signal to be looped through for normal viewing, but if I connect a VCR to the svideo or composite inputs, will the signal be 'up-converted' and be viewable over scart (or component) for viewing normally, or can I only use those inputs for recording??? Hope that makes sense.
I did want to chain everything via scart, but the scarts on my Freeview PVR are output only, so the VCR will need to connect to either the svid or composite inputs.
TIA
TIA
