DVR-MS to Mpeg convertor - where?
Discussion in 'Desktop & Laptop Computers Forum' started by hebawom, May 13, 2005.
  1. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    OK - didn't think I'd ever need to convert these files, since I just thought I'd only ever watch them on my media centre. But, I now need to.
    I've tried all the ones at the green button to no avail. I downloaded dcut - that didn't work at all. The DVR-MPEG program is controlled by a command prompt (way too scary!) and DVR edit I liked except when I chose the DVR to MPG convert option it said "option not implemented in this release" or something like that.
    Does anyone know any good programs - preferably free, but also commercial?
  2. DaveP
    DaveP
    I too have been struggling with this but in my case I wanted to burn a standard DVD that will play on any player.
    I'm now using the Nero Vision Express version 3. It is also supported in Roxio Media Creator 7.5.
    Not sure if that helps you though :(
    Dave
  3. Kamakazie
    Kamakazie
    Sep 20, 2004
    542
    +22
    supposedly, if you do not want to edit the files then you can just use the sonic ones provided in MCE. I think you have to download them if you got the OEM software though or something.... its a .msi so errrr have a look on the MS website.
  4. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    What do you mean, the sonic ones? Is there a converter program written by sonic? or you mean something else? Yeah, I've got an OEM version - please could you post a link to this program!
  5. HSC
    HSC
    Nov 23, 2004
    1,887
    63
    Coventry
    +135
    silly question - but what else do you want to watch them on..?
  6. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    I need them as mpegs so that I can add captions and effects to them in movie maker. We are making some short video clips for the youth group I run.
    I recorded Rocky the other night, and I want to talk about motivation with them - so am going to make a clip of Rocky running up the stairs (haven't fully got it figured out yet, but it'll come together when I'm doing it!)
  7. HSC
    HSC
    Nov 23, 2004
    1,887
    63
    Coventry
    +135
    oh ok
    im no expert at video editing - but I am led to believe that AVI files are the choice of file formats for editing (I could be wrong)
    for DVR-MS try this software (free trial)
    http://www.deskshare.com/dmc.aspx
    also note that protected DVR-MS files (DRM) cannot be converted.
  8. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    The Sonic Encoders are only available with an OEM 3-pack of Windows MCE as part of the Multimedia Feature pack. If you buy your MCE as a single pack it won't have this. It is intended for system builders only to install on their OEM Media Centers.
    Without this the Burn DVD option on More Programs of MCE will just burn a data DVD playable on a PC only. The Sonic Encoders change this option to allow you to burn a DVD that should be able to be played on "most" domestic dvd players. You cannot download them from the MS site or legally from anywhere else.
