Dvr-720h
Discussion in 'Blu-ray & DVD Players & Recorders' started by pcotton, Jan 11, 2005.
  1. pcotton
    pcotton
    Nov 26, 2004
    37
    Dont know if anyone owns the above but i have a problem. I transferred Hi-8 DV recordings to the 720H (HDD), copied to Maxell Single Sided DVD-RW and finalised. Playback on my own DVD player works fine (DV757i Pioneer), but discs are not recognised on any of the families DVD players (tried about 5 different units with no luck).
    Anything I am not doing, or could it be the media ? Should I try DVD-R's instead. Any help appreciated. :confused:
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    Have you recorded the DVD-RW in VR mode or Video mode?
    VR Mode will play only on models that support it, Pioneer recorders show the RW mark to indicate VR mode support, some other models will as well, and this would explain why it plays on your Pioneer DVD Player but not others.
    If you put the disc back in the recorder and it still allows you to record to it, it is VR mode, and it will confirm this if you click the Display button. If this is the case initialise a disc for DVD Video mode from the Disc Set-up menu, and try again.
    If it was in DVD Video mode, then it could be the case that the DVD Players do not like DVD-RW. A different brand of DVD-RW may help, but recording to DVD-R which automatically is always in DVD Video mode, and when finalised, will have the best compatibility, around 80-90%.
    Regards
    Philip
  3. pcotton
    pcotton
    Nov 26, 2004
    37
    Spot on Philip ...... Thanks
