Dvr-720h-S
Discussion in 'Blu-ray & DVD Players & Recorders' started by fusion7, May 8, 2005.
  1. fusion7
    fusion7
    Feb 7, 2005
    89
    i have this pioneer machine. was using the disc backup feature last night for the first time...it ripped the DVD (not macro vision protected or anything) without any problems...i inserted a brand new TDK version 2.0 DVD-R and the machien after whirring a bit just restarted and ejected the disc...
    i tried a few more discs and same result. is this machine just faulty? these discs burn fine with my lite-on drive in my DMS II media centre PC.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If you try another brand and it also happens you may well have a faulty machine.As a test,try a short direct to dvd recording and see if that works.
    Your loading mechanism may be faulty
