Has anybody experienced problems recording programs from the internal Freeview tuner on this machine?
If I set the machine up to record a program through the guide (maybe add a few mins to the end incase of over running) it goes through the motions fine, but when I go to watch the program it's blank. Listed on the HDD guide OK, but there is a black preview screen and when you play that program there is nothing but a black screen.
It started doing this occasionaly (yes, has worked fine previously) and now it seems to do it all the time, except when you record from its analogue tuner when everything is fine.
You can also view programmes through its internal Freeview tuner fine.
Any ideas?
Any ideas?
