DVR-530H-S noisy power off
Discussion in 'Blu-ray & DVD Players & Recorders' started by tigermad, Mar 20, 2006.
  1. tigermad
    tigermad
    Jan 2, 2004
    6,376
    Bedfordshire
    +645
    I have the above DVD recorder and really like it, apart from 1 thing.
    When you power off is it meant to take about a minute for it to turn off? Also it makes a grinding kind of noise when it is powering down.
    Is this meant to be there?
  2. Barrovian
    Barrovian
    Oct 29, 2002
    1,330
    United Britain of Great Kingdom
    +260
    Exactly the same here, can't say it's ever worried me.
  3. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    412
    Down South
    +19
    I just assume it's the hard drive shutting down ala a pc. It has a similar noise anyway??
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    Yes just the hard-drive powering down. The recorder does a bit of frantic house keeping before it goes off, and then shuts down. In order that hard-drives stop spinning as soon as possible (in case they are moved) a break is applied by telling the hard-drive motor to go back the opposite way (similar to a reverse thrust you get when a jet plane lands), it is this noise you are likely hearing as the motor coils try to reverse spin the hard-disc, the noise is due to the fighting opposing magnetic fields and quick deceleration.
    If the hard-drive was spinning and you "cut the power" (do not do this though) the hard drive would not make any noise as no reverse thrust can be applied as there is no power, it would then take a minute or so for the drive to come to a stop by itself, and during that time it is susceptible to damage if moved, hence the breaking of the drive where possible.
    The Pioneer recorders contain S.M.A.R.T. sensing, this means the drive will report any problems to the recorder and you would see an error message if anything was wrong with the hard-drive.
    Regards
    Phil
  5. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    We have a 530 at work and sometimes it just fails to finalize a DVD-R burned with high-speed copying from HDD (gets stuck on the menu creation) so I sometimes have to "cut the power" which is followed by a slow startup...but it is also a bit slow to start-up normally, and shutting down is alos a "long" wait...but this machine is sweet...
