DVR 530H Image Quality noticeable difference between cable and machine
Discussion in 'Blu-ray & DVD Players & Recorders' started by Iceman_, Aug 17, 2005.
  1. Iceman_
    Iceman_
    Aug 16, 2005
    16
    On Monday my Pionner DVR 530H arrived. However, after connecting it up as per instructions to my NTL cable box I could see a noticeable difference in quality of picture, when switching between the NTL cable box channel and the recorder channel when displaying the same imagery. Is this normal? I tried connecting SCART sockets with high quality 'THOR' branded cables. (Which I understand from mag reviews are very good).
    I also noticed that the cardboard box that the recorder came in was plain and unbranded (but had all the correct items contained in the box)
    The difference in quality of the image is like between normal terrestrial and cable. (Even without doing any recording on to the the hard drive) Is this normal with DVD Recorders :confused:
  2. nwgarratt
    nwgarratt
    May 5, 2002
    26,440
    +2,871
    What picture settings have you got the recorder on?
    For example, have you got NTL on RGB and the recorder set to composite?
  3. Iceman_
    Iceman_
    Aug 16, 2005
    16
    Hi nwgarratt
    The connections are both RGB and the quality of the Hard Drive compression is on the best quality
