DVR-5100H - need to replace dead hard drive
Discussion in 'Blu-ray & DVD Players & Recorders' started by shakur96, Aug 6, 2005.
  1. shakur96
    shakur96
    My hard drives needs replacing on my pioneer DVR-5100H. Am assuming a standard pc-type ide will do the trick and I know its 80gb. But what about RPM? what speed is the one inside running at. Plus is there any other things I should know before buying one. Any advice would be appreciated.
    Regards
  2. Phantom Phixer
    Phantom Phixer
    Jul 23, 2005
    127
    I recently took my dead Pioneer 530 to a Pioneer Service Centre. While there we talked about the possibility of replacing the drive. Apparently the new drive has to be intalled using a service cd or it will not work. I suspect the service cd reads the serial number of the drive and writes it to memory on the logic board, or it might write to a sector on the drive. This is checked on switch on.
    This might not apply to your model but beware.
  3. shakur96
    shakur96
    Noted mate, I'm hoping thats not the case. Anyone know if I need a 5400rpm or a 7200rpm etc?
