Quantcast
DVP-NS900V or DVP-S735D [SONY]
S
Saturn82
(Topic) Which one should I get. I can get the 735 somewhat "cheap" but.... I don't know!!??? Help!?
S
Steve_e42
If its a straight choice between 900 and 735, I would only go for the 735 if mp3 playback is important to you, otherwise 900 has to be the choice. But i would agree that the 905 is better still, it even has mp3!
S
Saturn82
Hmmm, as much as I fancy the 905 I can get the 735 for around 100$. I actually had the 735 for a brief moment but decided to return it, just to much for the DVD player at that time.
...Anyway, I could start out with the 735. I mean it's 100$ it's not like it's gonna ruin me :D
And from what I can remember the 735 is pretty awesome...
Adam Barratt
Is the 735 new or secondhand? If it isn't new or it has been used as a demo model, you can check the hours its laser has clocked. I wouldn't get it if it has more than a couple of hundred. The 735 was a great player, but it had some laser burnout issues.
Adam
Similar threads
