DVI -> YUV
Discussion in 'Cables & Switches' started by Rick1486, Mar 6, 2005.
  1. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Hi - is it at all possible to get hold of a DVI to YUV cable to connect my p.c. to my Denon 2105 amp for output to a Sony HS10 projector?
    It would need to be about 2m. - 3m. long.
    The reason I'm doing this is because I think I've got a dodgy input on the back of the pj, but the YUV component input works fine.
    Rick
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,599
    Rainham Essex
    +2,543
    In a word NO! :devil:
    DVI from a PC can be either a digital signal and YUV is analogue, or it is an analogue RGBHV (standard VGA) signal that is not directly compatable with YUV. Either way you will need to convert the DVI output to YUV so a simple cable will not work.
    Mark.
