DVI vs VGA
S
sainthalo
IS DVI a big improvement? Display will be plasma (eventually!)...
Nic Rhodes
It CAN be a worthwhile improvement. For most systems I prefer DVI but at the highest level the difference get less, to where is it is tricky to spot the difference. I wouldn’t buy a plasma or panel projector however without the option nowdays but it is a very changing marketplace and changing standards on DVI / HDMI etc so do some legwork first to make sure you are informed about what you are buying. I like the idea of these plug in boards some of the plasmas are using.
