DVI vs VGA for Long Cable
Discussion in 'Cables & Switches' started by scothouse, Aug 13, 2005.
  1. scothouse
    scothouse
    I need to string a long cable (50 - 75 foot) from desktop to monitor, and can use either DVI or VGA cable (as desktop and monitor accept both interface types). Which do you recommend for this purpose? That is, is one better than the other when used in a long cable? Thanks, -Scot
  2. Dutch
    Dutch
    Dec 5, 2002
    2,559
    3
    North Yorkshire
    +256
    DVI is really limited to about 7m, but longer lengths are possible using top grade stuff from companies like Bettercable - but at a price of course! Have a look at Lindy for excellent quality VGA cables at reasonable prices. Hope this helps.
    http://www.lindy.com/uk/productfolder/03/37/37254/index.php
    Steve
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    scothouse
    15 - 23m is a long run for Analogue RGBHV (VGA) and or Digital RGB (DVI) so both potentially require more than just a cable.
    The DVI solution will most likely produce the sharper image - how does the system look on Analogue vs. Digital with short cable runs.
    A Gefen DVI Extreme Fibre optic DVI cable will cost you around £390.00 for a 20m cable.
    See http://www.gefen.com/kvm/cables/hdtv_dvi.jsp#hdtvextreme
    A BetterCables Display Magic II 15m DVI will cost you around £240.00 - though you may find you require a signal amp if your Graphics card is not up to 'driving' the long cable.
    See http://www.bettercables.com/15me4febecad.html
    A decent quality 20m HD15 (VGA) cable will cost you around £150.00 and I'd budget for a VGA Line Amp with variable drive (approx £150.00) as your sure to notice a drop off in signal quality without one.
    See http://www.kramerelectronics.com/indexes/item.asp?desc=210
    I'd suggest you find someone who can provide a couple of options for you to try out in your system to evaluate what works best for you.
    Best regards
    Joe
  4. MADMAND
    MADMAND
    Aug 4, 2005
    343
    +8
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    MADMAND
    I take it if scothouse buys one of everything on the page he'll have a 20m cable :)
    Best regards
    Joe
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    or use baluns?
  7. bri.s
    bri.s
    Aug 6, 2005
    281
    28
    Livingston
    +28
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    bri.s
    It would be wrong to say the Lindy DVI cable wont work for you - it may!
    As ever my advise is order either one knowing it may not work in your set up - so ensure you can return it if you have a problem.
    Best regards
    Joe
