DVI -> VGA
Discussion in 'Blu-ray & DVD Players & Recorders' started by shaithis, Apr 24, 2005.
  1. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    Having a spare VGA port on my plasma and wanting a better player I was wondering if its possible to hook up a DVI DVD player to the VGA in with a DVI > VGA dongle?
    If so are there any downsides/limitations?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    It's not as simple as that - when is it even in AV :rolleyes:
    DVI comes in 3 different versions:
    DVI-A - this is an analogue connection and basically the same signal as VGA, but on a DVI lead
    DVI-D - this is a digital only connection
    DVI-I - a combination of DVI-A & DVI-D on a single connection
    So if the DVD player is outputting either a DVI-A or DVI-I signal then you will be able to connect it to the VGA input on your plasma with a direct DVI to VGA lead and no conversion. But AFAIK, most if not all DVD players will be outputting DVI-D over the DVI connection and therefore there is no way of connecting a digital signal to an analogue input without conversion. It also gets more complicated as DVI-D (and HDMI) from a DVD player will almost certainly carry copy protection in the form of HDCP, which will in all cases prevent a conversion from digital to analogue - well legally at least :devil:
    Mark.
  3. english_bob
    english_bob
    May 10, 2001
    1,528
    Maidstone, Kent
    +220
    Jesus, what a great standard! :rolleyes:
  4. Kamakazie
    Kamakazie
    Sep 20, 2004
    559
    +22
    what about outputting through RGB scart and using the JS RGB>VGA converter??
  5. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Yes, that should work fine.
    Steve
