DVI versus RGBHV
Discussion in 'Projectors, Screens & Video Processors' started by ispra, Jan 23, 2005.
  1. ispra
    ispra
    Jan 9, 2005
    13
    Please someone give me advice on the relative merits of VGA to RGBHV and DVI to RGBHV in terms of perceived image quality.
    The display device is a Barco 801s Data.
    Is there a real benefit in going DVI via a Digital connection box with RGBHV out for viewing DVDs played on a PC and HDTV from Euro1080 (the decoder has both DVI & RGBHV outputs). Is the extra cost justified?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    Your display is analogue RGB. All you are doing is changing where the digital to analogue conversion is taking place, from your pc and euro box to an external transcoder. You need someone who has the same set up to tell you if there's a difference I guess. If the transcoding is done correctly there shouldn't be any visible difference I'd think
    Gordon
