Dvi to VGA 5/10m Cable
zanic
Hi guys i looking to connect my Pc to TV (SonyKDL32V4000u)
I believe DVI to VGA is the best way to go. Just wanted to know where i can find either a 5 or 10m cable and how much this will cost
Also which cable should i use to give the best audio?
Joe Fernand
AVForums Sponsor
Hello zanic
There are various DVI connectors - some are Digital only some have Digital + Analogue.
If you have a DVI-D (Digital) only connection you require more than just a cable.
If you have a DVI-I (Digital + Analogue) then a DVI-I to VGA cable is an option.
You need to work out what type of DVI connection is on your PC - see http://www.ddwg.org/dviinfo.asp
Joe
