DVI to scart adaptor
Discussion in 'Cables & Switches' started by Colin Parker, Nov 27, 2004.
  1. Colin Parker
    Colin Parker
    Is there such thing as a DVI to scart adaptor?
    I want to use the DVI output on my Denon 1910 to go to my TV. I'm told the quality is much better that way, but the HQ100 doesn't have DVI in.
  2. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,258
    63
    Perth, Western Australia (Originally Ireland)
    +228
    Not sure if there is an off-the-shelf adaptor for your needs, but even if there was you would be converting from analogue to digital anyways and losing the benefits of DVI, so going into SCART or component on your TV should yield the best results.
