DVI to M1 adaptor?
Discussion in 'Cables & Switches' started by Les E, Oct 6, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I am thinking of buying a Denon 1910 and the Screenplay 4805/5700 (depending on budget) and connecting them via DVI-D.
    The Denon has a DVI-D out but the Screenplay Projectors need an M1 adaptor to convert the cable to fit.
    Does anyone know whether the Screenplay projectors come with the adaptor or where I can get one from (or even a DVI-D - M1 lead!)?
  2. stormtide
    stormtide
    Les,
    Unfortunately, none of then Screenplay PJs come with the adaptor; however, I am sure the shop supplying the PJ will provide the adaptor FOC. Sevenoaks supplied one with both the 5700 and 4805 FOC when I ordered. :)
    Stu
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,786
    The Borders
    +3,290
    Les E
    I'm not giving them away - as per stormride's suggestion! (though maybe if you were buying the system from us we might consider it!!!)
    We supply the Gefen DVI to M1 adapter - and so far 99% of them have gone to ScreenPlay owners - see http://www.gefen.com/kvm/product.jsp?prod_id=1498
    We have the adapters in stock along with a range of long DVI cables if required.
    Best regards
    Joe
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
