DVI to HDMI
Discussion in 'Cables & Switches' started by judderman85, Sep 5, 2007.
  1. judderman85
    judderman85
    Decided to post here as I might get a better response than in the LCD forum.
    Having recenty bought a Samsung LE32R87BDX I was having to switch between 2 different VGA inputs, my computer and my Xbox 360.
    So, I bought a DVI to HDMI cable and hooked it up to my PC so I could swap inputs at the touch of a button. However I turned myb computer on and the picture is awful, it looks as though the res is off. I have tried fiddling with the res and checked out the R87 settings thread but can't get anything to work. I'm running a Radeon X800 if that helps.
    A bit better. I updated the drivers and they came with specific controls for using the DVI output. So now the res is the recommended on the R87 thread and the picture is better but still sub optimal (i.e worse than the same TV and computer were using VGA)
    Can someone explain to me why the same TV and source use different resolutions depending on what lead I use and is there much chance of impriving the picture.
    To be exact the picture on videos is fine it's on things such as text where it looks slightly 'off' as though the resolution is off by a couple of pixels.
    Thanks for any help.
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    I'm not familiar with the exact TV model, but a common issue is that the non-computer signals go through a scaler that is aimed at making sure that the picture fills the screen and looks good, no matter what resolution it it. To my surprise that is done for DVI/HDMI signals as well, even though you'd imagine that 1:1 pixel; matching would be smarter - at least as an option! The VGA input can work differently though, since computers often expect 1:1 matching, and also use text where the edge definition of text matters a lot. So, for a film type signal it can look great - you wouldn't notice a couple of pixel stretch across the screen. But, for a PC is can look dire, with bands of 'smearing' across the screen.
    In terms of improvement, I don't have much to offer, other than using the VGA input which may bypass the scaler (it sometimes does).
    Greg
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,720
    The Borders
    +3,513
    Hello judderman85
    Gregory is correct re the non acceptance of Native signals on many HDMI Inputs - its all down to the choice of HDMI Receiver 'chip' the Display manufacturer chooses to design into the Display.
    Some HDMI Receivers will only accept 'Video' resolution signals and the Display then has to scale the Input signal to fill the pixel array - in most cases its better to revert to Analogue HD15(VGA) for a PC signal.
    See http://www.siliconimage.com/products/productfamily.aspx?id=1&#29
    A very decent quality 2x1 Automatic VGA Switch will cost around 150.00 GBP.
    See http://www.kramerelectronics.com/indexes/item.asp?name=VP-211DS
    Joe
