DVI to HDMI
Discussion in 'Cables & Switches' started by Monkey Alan, Aug 15, 2005.
  1. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    I want to connect my P.C to my projecter which has a HDMI socket.
    I brought a lindy 10m DVI-D cable and ordered a DVI to HDMI adaptor which hasn't arrived yet. But I've just tried the cable from my P.C to the monitor and it doesn't work, maybe because its too long?
    Anyway if I can't get it to work with my monitor I don't think theres much hope of it working with my projector when the adaptor comes.
    Should I Send the cable back and ask them to send me a DVI to HDMI cable as I have read on here HDMI cables are better over long distances.
    http://www.lindy.com/uk/productfolder/04/41106/index.php
    Or will this cable be the same as I've got just with a hdmi plug on the end?
    Hope someone can help, thanks.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,732
    The Borders
    +3,079
    Monkey Allan
    The distance you can send an HDMI signal over compared to a DVI signal is down to more than just the cable; HDMI to HDMI connectivity was designed to enable longer cable runs than DVI ever was.
    Its just as likely you wont get a signal with the same spec of cable pre fitted with an HDMI connector on one end - the DVI transmitter in your PC is part of the problem and you'll require a low loss DVI cable and/or a DVI booster; see http://www.gefen.com/kvm/product.jsp?prod_id=2937
    Have you tried the PC to Projector connection with a short DVI cable to verify everything is working?
    Assuming everything is working as expected on a short cable run then a 15m BetterCables Display Magic DVI to HDMI or DVI to DVI cable is more likely to work without requiring a signal amp.
    See http://www.gefen.com/kvm/product.jsp?prod_id=2937
    Best regards
    Joe
  3. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    :hiya: Thanks for the reply. good news is I got it working. I was giving it one more go before I sent it back, I pluged it in an got nothing again so I thought I may as well restart the P.C thinking its not gonna work anyway but bobs ya uncle its works a treat now. :smashin: Just need to wait for the dvi to hdmi adaptor to try it with my pj.
    I think I understand what you are saying about HDMI cables, am I right in saying HDMI cables are only better if a HDMI output source is used? If so I never understand why people buy long HDMI to DVI cables because its far cheaper to buy DVI cables and an adaptor.
    Thanks for your help, hopefully I'll have no more probs now. :)
