I also checked for software upgrades for the LG but like you I'm running v3.35.1 and no software updates are available. I also checked the LG website - that was a farce and complete waste of time!
Over the past 3 weeks or so I've read loads of forums and sites detailing issues with NVIDIA drivers and some panels, notably many were LG, and in some cases after a quick registry tweak the problem was solved. Alas I can't identify anything for this particular issue, and in my case I know it's not just NVIDIA, I've also tried, like you, an ATI Radeon video card - same problem.
I also downloaded a program to read the EDID information (EDLIM EDID Viewer), but it returned so many entries I couldn't identify which one was for the LG panel, if any,maybe this was because I've had several panels connected to the computer over the past 12 months. As with most registry entries they are often written but rarely removed!
I wouldn't be surprised if there isn't a setting that can be set to completly ignore EDID information, assuming this is the cause, but I have no idea what or where it is.
I am still looking for a solution, if I identify one I'll post it here, but after many hours of searching I've effectively given up.
Good luck with your investigation, if you identify any possibilities I'm happy to give them a try...
After Posting this I have tried several things to try and overide the DVI or HDMI ports to try and force some form of output via DVI or HDMI, so far with no success. However, in the process I have discovered several items of intrest and one which seems to give some good pointers is this one, http://www.spatz-tech.de/tutorial.htm. As a result I downloaded powerstrip which, if nothing else, has helped me get windows to see my HDTV as 32LG5000 and not as a "generic non-plug and play" monitor which it was doing. My gut feeling is that the HDTV isn't utilising the 'Hot plug signal' or the Video card (actually cards x 3, 2 NVIDIA and one ATI) is ignoring it (but it does work with other HDTVs - so my suspicion lies with the TV). Using Moninfo I can read both the analogue (VGA) and Digital EDID info - And along with all of this I'm getting very frustrated!
