DVI to HDMI ? confused?
Discussion in 'TVs' started by whiteswan, Dec 9, 2004.
  1. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    Right As some of you know I have connected my pc to the new tosh dlp and am impressed with the pic - especially 720 and 1080 stuff............but I only get a 4:3 output pic from the pc.
    Now I think this is because I am using the pc vga port...........becuase if i feed my xbox into the component port via xbox media centre/player i can adjust the xbox to fill the whole screen whilst playing xvids etc.
    My pc has a dvi out on its graphics card and the tv has hdmi on the rear of it.
    So is it as simple as getting a dvi to hdmi cable to connect the two?
    Or do i need hdmi to hdmi with an adaptor at one end to change the dvi to hdmi?
    My head hurts!
    Dave, Oldham.
  2. Wij
    Wij
    Nov 17, 2003
    977
    Northants
    +34
    I presume you've made sure that the resolution is set to 1280x720?
    Sean
  3. whiteswan
    whiteswan
    Dec 9, 2002
    878
    Oldham
    +43
    If I set the display options to display 1280 x 720 the screen goes blank -
    I have it set to 1024 x 768 as in the manual the Tosh says that is the display it supports.............
    I get a pic set at this resolution - but its just a 4:3 pic I have a Radeon 9800xt graphics card - its a medion 8083 pc.
    Dave, Oldham.
  4. Wij
    Wij
    Nov 17, 2003
    977
    Northants
    +34
    You have a 46WM48? if so its native res is 1280x720 so it should work best at that really,only reason I can think as to why the screen goes blank is because the refresh is set at a level it cannot handle.
    If its a different model I apologise :)
    Sean
  5. AV Junky
    AV Junky
    Oct 30, 2002
    1,211
    Cheshire, UK
    +68
    Try 1280 x 720 with refresh at 60 Hz. This is the same as 720p (at 60 Hz). Either of the options for the digital connection you mention should work equally as well. DVI and HDMI were designed to be fully compatible right from the outset.
  6. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    From reading threads on Toshiba's 32WL48 LCD screen which seems (barring the display technology) to have exactly the same spec connections wise, their TV's will only accept a 4:3 resolution via the VGA port, and people don't seem to be having any success with DVI to HDMI adapters.
    However, as you mention that you've got an ATI graphics card, you might be abl to use
    this ATI DVI to component adapter....
  7. Wij
    Wij
    Nov 17, 2003
    977
    Northants
    +34
    Hmm this could rule out this TV for me also.
    Anybody got one and can confirm if you can get its native res 1280x720 through the HDMI connection (DVI to HDMI from my HTPC),I see absolutely no reason why it wouldnt really?
    If not I'm deffinately gonna have to look for something else :)
    Sean
  8. Notchy
    Notchy
    Note DVi only carries video, HDMi carries both video and sound, un-suppress in pure digital format with no compression ensuring you get maximum quality. Another word you simply cannot get better than this new protocol. HMDI to HMDI is the ultimate set up.
    Delow is a website where you can purchase a DVI to HMDI cable. Weather it will solve the 4/3 to 16/9 format I don't know but you could email them
    http://www.beststuff.co.uk/hdmi_and_dvi_leads.htm
  9. deejay-mo
    deejay-mo
    Sep 15, 2005
    4
    I'm also thinking about getting one of these. Tried it in John Lewis the other day connected to the vga input, and just got a blank screen at 1280x720 60Hz.
    Anybody managed to get this res working? If so how?
  10. Toekiller
    Toekiller
    Perhaps Powerstrip to the rescue?
  11. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
    This has been covered a dozen times, try looking back. The Toshiba will happily run 720p (50hz or 60hz) or 1920x1080 (I don't tend to use it this high, the icons are so small and my eyes are not what they used to be) if you so desire, but only on HDMI. The vga will only go to 1280x768 and gives a poorer image next to the digital connection. If your only using the vga........why?? Boy are you missing out.
    I use a DVI to HDMI adapter and then a quality triple screened HDMI to HDMI cable. Or you could use a DVI to HDMI cable, get a good one circa £40/£50. The cheap ones bleed noise and the silly expensive one's, well I can't see the difference. The sound goes via optical to an amp.
    Read this from ages ago.
    http://www.avforums.com/forums/showthread.php?t=206350
    This is the cable I used after trying nasty to mortgage level.
    http://www.hificables.co.uk/ProductDetails/mcs/productID/11276/
  12. JayList
    JayList
    Why do you double up on cables? Sureley the image will have degraded already by the time it feeds into your hdmi to hdmi cable? Or is it just a case of you need the length of cable?
    I can understand a dvi to HDMI cable direct into the set. :confused:
  13. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
  14. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
    Why yes, an adapter. But a nice gold plated contact one. Why? Because I expect connections will become HDMI (eg SkyHD) at some point and I don't want to buy more cables at £50 a pop. Signal degrades over length (voltage drop and more noise). If you make an adaptation you will increase the resistance at the connection, but gold contacts help and it’s only an inch long fully shielded.
    It also helps with the wear on the graphics card pins which bend just looking at them.
    http://www.hificables.co.uk/ProductDetails/mcs/productID/11277/
  15. JayList
    JayList
    I'v e bought a 10 meter dvi cable. The dvi standard is only up to 7.5 m but t he company I've bought it off recon they have that problem licked by using better shielding etc.
    It's only for the 19" lcd monitor though so I don't need the best image ever (althougt Battlefield 2 better look good) :D
  16. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    Can you share your experience?
    What kind of problems do you get with it? Image degradation?
  17. SeerOfSouls
    SeerOfSouls
    May 28, 2010
    20
    3
    +4
    i may be dead off here but i cant find an answer
    sry :(
    can i uses a DVI to HDMI cable to connect my pc to my tv?
    because when ever i use DVI my display goes out sych with the monitor
