dvi to hdmi bad artefact's AE700
Jimbob Uk
Hi there
i need help advice with my 3 month old Panny AE700
I'm hooking the pc up with DVI to HDMI adaptor and a 4mtr cable but when i do this i get real bad fuzzy Artifacts at random times out of the blue, the only way i can fix it is to try get the screen res to change (but that is hard to see mouse pointer cause the Artifacts) Or unplug the hdmi then put it back in again and I'm sure this is not doing my pj any good.
The pj is fine if i use VGA connection but im getting cheesed off that i spent 1K on some thing and i can't use part of it to the full, Any one out there had the same problems ?
The panny is 1.07 and it running off a ATi x800XTPE, QED DVI to HDMI adaptor but a no-name 4mtr cable
Could this be a simple thing like a crap cable ? or is it more serious ?
Thanks Jimbob
Ekko Star
Sounds like the cable. Get a shorter length and I'll bet it'll do the trick.
