DVI to HDMI adapters and HDCP issues
Discussion in 'Cables & Switches' started by Jhaughn17, Mar 24, 2005.
  1. Jhaughn17
    Jhaughn17
    Looking for info and or anyone who has experiance problems with DVI to HDMI adapters gliching passing HDCP encription. Having problem between a Denon 2910 DVD player connected through a DVI hub then 15 meter DVI cable to a Sim2 Domino 30H projector. DVD freezes up both itself and the projector up. Have to reboot both DVD an projector system. Any help much appreciated.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    i would suggest that a 15m DVI cable was pushing it a bit - the usual limit for DVI is around 8m. Hope this helps.
    Steve
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,882
    The Borders
    +3,117
    Hello both
    Jhaughn17 - Which Hub, Adapters and Cables are you using ?
    Dutch - were getting very good results with our 15m BetterCables cables.
    I can run DVD Player > Lumagen > Projector using a 15m cable between DVD and Lumagen and a second 15m cable between the Lumagen and the Projector with no hiccups.
    Best regards
    Joe
