DVI to AE300 from Denon A11
Discussion in 'Projectors, Screens & Video Processors' started by sunlink, Dec 12, 2003.
  1. sunlink
    sunlink
    Received DVI cable from Lindy yesterday and tried in vain to output DVI to my panny AE300 from a Denon DVD A11. Why is this not possible and if it is what is the set up procedure.
    Steve:)
  2. carl.rayer
    carl.rayer
    I don't think the AE300's DVI input is HDCP compliant (http://www.gumboot.co.nz/forums/topic.asp?TOPIC_ID=27), and according to Avland's listing of the Denon DVD-A11: 'HDCP Compliant (DVI Equipment must comply with HDCP)'.
    If anyone knows of an intermediary device that converts HDCP-complaint DVI to non-HDCP-compliant DVI, please post here (as I have an AE300, and the same issue, as well :( )
