dvi through wall
Discussion in 'Cables & Switches' started by godisi, Jun 29, 2004.
  1. godisi
    godisi
    Hey people, im setting up a ht bedroom and im nearly complete with the cabling. Im going to be buying a long dvi cable to go from my cieling mount pj to my htpc. What i want to do is run the cable up the cieling mount pj pole and run it down to the wall side of the htpc, i will have to create a hole for the other end of the dvi to get throught to the pc.What i DONT want to do is create a big hole in the wall which i will have to do if i would like to get this cable through to the PC. Is there anyway i can open up the dvi cable at one end so the hole only has to be big enough for the wire to go through, and then recconeting the dvi connection end back after its been wired through.
    cheers,
    btw what is a good 10m dvi -dvi cable
