dvi switching
Discussion in 'LCD & LED LCD TVs Forum' started by killer10971, Feb 5, 2005.
Tags:
  1. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    i take it that when the dvi input is sent a signal it dosnt switch to the correct channel (like the other ext 1-3) im using a supra cable from a denon 1910
    and does the dvi channel have the ability to store its own picture settings that are seperate from the other channels , i thought i read it on here somewhere
    cheers
  2. Hunterm8
    Hunterm8
    Mar 5, 2003
    115
    16
    Leicester
    what tv. 9986 doesnt switch to dvi but does have separarte sets
  3. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    sorry
    its a philips 37pf9986 , so as i understand it they dont autoswitch to dvi , but dvi has its own setup
    can anyone post their recomendations for dvi
    one other point "active control" on or off , seems a bit pointless using the settings posted here when active control seems to overides them to optimize the picture
    many thanks
  4. Alan D
    Alan D
    This is what I have my 37PF9986 set to using DVI-DVI from a Denon 1910.
    Contrast: 63
    Brightness: 30
    Colour: 70
    Sharpness: 3 (some prefer 2) (not applicable at 720p)
    Tint: Normal
    Digital Options: Pixel Plus 2 (not applicable at 720p)
    Dynamic Contrast: Minimum
    DNR: Minimum (not applicable at 720p)
    Colour Enhancement: On
    Active Control: minimum or off if you prefer
  5. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    thanks ill try it
