DVI switch
Discussion in 'Plasma TVs Forum' started by Toine, Sep 9, 2004.
  1. Toine
    Toine
    Hi there,
    I'm looking for a DVI switch wich can switch Analog (like VGA) as DVI-I.
    I was looking at Gefen, but they can't help me.
    Someone here can?
    regards,
    Toine
  2. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
    Never heard of such a thing. Have you thought about buying some cheap DVI-vga adapters and using an RGBHV/VGA switcher, or do you need to switch DVI-D at same time?
    Gordon (posting from Elliots PC in USA at CEDIA, Indianapolis)
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  4. Toine
    Toine
    Is no option.
    I need to switch DVI-D/I also...
    Only one option : a switch wich can switch analog and digital.
    I was hoping there is a good switch wich does a one-on-one switch, so with no intelligence in it, like the Dtronics or the Gefen does.
    Regards,
    Toine
