DVI Splitter
Discussion in 'Cables & Switches' started by Nostromo426, Feb 20, 2005.
  1. Nostromo426
    Nostromo426
    Nov 16, 2004
    28
    Essex
    Not sure if this is the right forum but here goes.
    My PC graphics card has DVI out currently feeding my Sony LCD pc monitor.
    I also wish to send this signal to my TH-50PHD7 plasma DVI input blade.
    My question - is there a cabling "box" that accepts DVI input from my PC graphics card with 2 DVI out (DVI in=1/DVI out=2)
    Any suggestions would be appreciated
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,043
    The Borders
    +2,519
  3. Nostromo426
    Nostromo426
    Nov 16, 2004
    28
    Essex
    Thanks for the link Joe - I'll check it out
  4. hjkrebs
    hjkrebs
    Oct 23, 2004
    19
    Specifications:
    • Video Amplifier Bandwidth 2.4 GHz
    • Actual Bandwidth: 1.65 GHz
    • Input Video Signal: 1.2 Volts p-p
    • Input Sync Signal: 5 Volts p-p (TTL)
    • Single Link Range: 1080P/1900x1200 @60HZ
    • DVI Connector: Molex 24 pin female connector
    • USB Input Connectors: Type “B”
    • USB Output Connectors: Type ”A”
    • Video In: DVI-I Dual Link
    • Video out:DVI-I Dual Link
    • Power Supply: 12 VDC
    Joe, this 60Hz, does that mea that this DVI switch only work switching computer video, and not Home cinema Video?
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,043
    The Borders
    +2,519
    Hello hjkrebs
    We use both Gefen and Zektor Digital Switchers in many UK and Euro systems with no problems - same goes for the Gefen and Zektor Distribution amps; we have plenty of multiple input systems with all sorts of signals being switched and distributed.
    Best regards
    Joe
  6. zAndy1
    zAndy1
    Nov 26, 2002
    19,598
    2
    5
    163
    +6,696
    I'm probably going to need something like this as I want to connect the DVI output of my HTPC to both my Sanyo Z3 and my soon to arrive Sagem HD-D45. Obviously at the moment HDCP isn't an issue for me but it may well be in the future so thinking ahead do I need the HDMI splitter since that seems to be the only one that passes HDCP through both outputs? Is it ok to use a DVI->HDMI adaptor to connect my HTPC to this and then use HDMI->DVI adaptors to connect my projector and Sagem TV?
    Cheers,
    Andy.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,043
    The Borders
    +2,519
    Hello zAndy1
    The HDMI and DVI adapters we use do seem to be 'transparent' so no problems adapting existing cables - where possible I try and avoid adapters but its not always possible.
    Best regards
    Joe
