DVI Quick questions
Discussion in 'LCD & LED LCD TVs' started by makey, Jun 30, 2005.
  1. makey
    makey
    Mar 11, 2004
    185
    +15
    i bought a dual 26"lcd from asda
    it has a dvi connection and 2 scart
    i have connected my cable box with scart
    the question is if i buy a dvd player with dvi connection and connect it
    will this only give me pix with no sound and if so how do you get sound from player to tv
    thank lads
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    You should have sound connectors near the DVI port. Use RCA/Phono cables (White and Red ones) to connect the sound from your DVD players' audio output to the audio input that corresponds to the DVI port.
  3. makey
    makey
    Mar 11, 2004
    185
    +15
    thanks mate
