dvi question
Discussion in 'Cables & Switches' started by Baron Von Doom, Jan 2, 2007.
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,562
    worthing
    +176
    im looking for a dvi cable to connect my laptop to my projector. both are
    dvi-d.
    ive noticed that some dvi-d cables seem to have less pins than others.i believe these are called single link. there is nothing in any of the instructions for either machine on cables. is this type of cable ok?
    also i have seen a cheapish dvi-i cable, would this work?
    thanks
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    You won't need dual link.
    Single link DVI uses a 165 MHz transmitter to provide resolutions up to 1920x1080 at 60Hz.
    In the unlikely event that you need greater than this, e.g. 1920x1080 at 85 Hz, dual link can do it; however, the equipment at each end of the link would have to have 2 transmitters and 2 receivers to make use of it.
    Chris Muriel, Manchester.
