DVI Output
Discussion in 'Desktop & Laptop Computers Forum' started by Rasczak, Sep 4, 2003.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Does anyone here have a DVI output on there PC going to a similar input on a projector/plasma? If so can anyone recommend a PCI card for adding such DVI output? Do any offer DVI input as well?
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Yes, I use a Radon 9500Pro to feed images via DVI to my pj. Most mid-top range Video cards now have DVI output as well as VGA and many with S-Vid also.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Excellent - thanks for that - when I upgrade my graphics card in a few months I'll make sure it's got it.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Don't I feel stupid! I've already got a DVI connection on my current graphics card :clown: I didn't know they looked like that!
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    For HTPC use anything from Radeon 7000 upwards should do the job OK.
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    It's a fairly elderly nVidia GeForce Ti4600. A good card in it's time but now a bit old. I'll be upgrading to a top of the range card soon (ready for Doom III and HL2 :D) so will make sure it does DVI before I buy.
  7. philipb
    philipb
    Mar 6, 2002
    2,032
    63
    Swindon
    +148
    Rasczak
    Did you really mean PCI card? If so you might struggle to find one with DVI. Certainly just about all AGP cards come with it, but I'm not sure about PCI cards.
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Yes I did. I was just thinking from an upgrade point of view without buying a new graphics card (I only have 1 AGP slot) and I half thought you might be able to get them in the same way as you can get iLink connections on PCI cards.
    Then I actually had a look on the back of my PC and saw my graphics card already has a DVI Connection :blush:
  9. Kramer
    Kramer
    Custom resolutions are limited on nVidias when using DVI.Either 1024x768 or 1280x1024 IIRC. No problems unless you want to "pixel match" your output & display device requires a higher horizontal resolution.
    Radeons are better :)
