DVI output on Graphics Card ?
Discussion in 'Plasma TVs Forum' started by Darbyweb, Jul 19, 2003.
  1. Darbyweb
    Darbyweb
    Mar 18, 2003
    58
    Bedfordshire
    Just picked up a shuttle PC from my supplier. I spec'd a suitable Graphics Card with DVI output. Its an OEM card with Radeon Chipset.
    The card has two by High density D's and 1 x S-Video. There is no DVI socket that i can see...
    Im sure i'm right in saying that its has to be a DVI socket to output DVI ??
    I want to connect this straight to my Pioneer PDP-433MXE which has a DVI input. I see VGA to DVI cables, but i cant believe this is right.
    Help appreciated.
    Dean.
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    344
    16
    I think you've been sold short. Proper DVI cards have the same DVI socket on them that you have on your Plasma.
  3. GAmbrose
    GAmbrose
    Jul 5, 2003
    996
    43
    Essex
    +184
    Which Radeon is it?
    The 9700's have DVI.
    Gary A
  4. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
  5. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi lumpsucker,
    I don't think you can plug a DVI-I cable into a DVI-D socket.
    Steve
  6. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    Hi Steve,
    yes, sorry you are right. What I meant was that the Graphics cards have DVI-I ports and the Plasmas have DVI-D ports but you can connect the 2 by use of a DVI-D cable.
    Simon
