DVI output HDMI input
Discussion in 'Cables & Switches' started by goldy777, May 24, 2005.
  1. goldy777
    goldy777
    I have a DVD player (Samsung HD748) with a DVI output and I want to connect it to a projector Panasonic AE700E which has a HDMI input. Do I need any special cables or any adaptors ?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    Hello goldy777
    'Special cable' - no not really all you require is a properly designed/constructed DVI to HDMI cable; lots of options these days.
    The length of cable required may have some bearing on which cable you want to consider for your install - DVI has limitations on cable length.
    Best regards
    Joe
  3. goldy777
    goldy777
    Joe thanks for the reply. The length of connecting cable involved will be about 16 - 17 feet. From what I've read this would seem to be short enough to ensure that no limitations are met or signal loss occurs. Would you agree ?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,762
    The Borders
    +2,464
    Hello goldy777
    At 5m (16.4') we've had very few problems - though step up another couple of meters and it can be a quite different story.
    You could consider a budget Molex or higher quality BetterCables at 5m - others may have alternative solutions.
    Best regards
    Joe
