PhilCTTE
A few months back the DVI output failed from the PSM and the DVD32R display went crazy. Displaying all sorts of nonsense. No error codes just spurious characters. For a few days the DVD would not reset. I left it off for a week and tried again and since then it seems to be performing ok, but the DVI output of the PSM is still dead. I leave the unit powered down and only fire it up for the odd CD / DVD . Believe it or not I'm one of the few who still have the original transport mech working. I know that I should get the unit overhauled along with my 7 year old AV32R DP unit, but do not have the spare readies. So for the moment I've opted for the component output from the PSM which works fine for DVD,s which is connected to the Pioneer media box. Originally I had SKY+ routed thru the DVD player and output via DVI to my Pioneer media box, but after the DVI failed I had to route the SVideo out from the SKY+ box directly into the Pioneer media box. Surely if the component output is working why does this not output the SKY signal. I think that there maybe other problems with the inputs on the DVD player or AV32R. To be honest I've totally forgotten how to connect SKY+ the AV32R and the DVD PSM to Pioneer media box and I'm not sure which connections are working or not. I find the PSM labels on the DVD player confusing. Do I take the Svideo out from the SKY into the sVideo "SAT-S" on the AV32R then output from AV32R svideo "OUT + OSD" into the PSM "in-S" connection then output all signals via the PSM "component (G) (B) (R)" into the component input of the Pioneer box.? Hope all is well for all you TAG users out there many thanks in advance
