DVI or VGA ?
Discussion in 'Home Cinema Buying & Building' started by glofuel, Apr 28, 2007.
  1. glofuel
    glofuel
    Hi, Anybody have experiance using HDMI PC to LCD ?
    I am using a samsung LCD TV as a PC monitor connected with a normal VGA cable, However would I get an improvement on picture quality if I use a cable to a HDMI/DVI type cable which my PC/TV can support ?
    Is it worth the expense for a cable, I need a 10 - 15 mtr cable
    Comments appreciated
    Ian
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    With that length you would would need an expensive cable ; I would stick with VGA ; on most cases the difference in quality isn't discernible.
    Chris Muriel, Manchester
