stonecoldbossma
Hi All,
I have just purchased a Samsung 50" plasma (PS50C7HDX). I am running this through Vista MCE.
The problem I have is the tv only has a VGA and HDMI not a DVI connector I wanted to use the HDMI input not the VGA to get the highest quality ... I am doing this using a DVI cable from my graphics card and then using a DVI to HDMI convertor. This hasnt worked out how I expected as I can not use any of the TV adjustments for PC input built into the tv as it only sees this connection as an HDMI .. I have very limited resolutions I can use in games etc (hd ones I think, hope this make sense?).
I best setting I am going to get is if I use the VGA connector on TV (I think), to do this I will use a DVI cable from my PC and then a VGA converter (my GF only has DVI out) but I am worried I will not get the best quality? ...is VGA any good the TV's resolution is 1366 x 768 VGA OK for this especially in the future when I am getting HD content from telewest, hd dvd player etc.
Any help would be appreciated I am thinking of sending the TV back and getting something with DVI input ... am I being too finicky .. I just want the best quality I can get for my money, and not regret it in a few years when there is more HD content about.
Thanks in advance.. as said any comment, advise would be very much appreciated I only have a few days to send it back.
Lee
Lee
